Ir para o conteúdo principal
Moto G4 Front-facing Camera Replacement
O que você precisa
  1. Moto G4 Front-facing Camera Replacement, Back Cover: passo 1, imagem 1 %32 Moto G4 Front-facing Camera Replacement, Back Cover: passo 1, imagem 2 %32 Moto G4 Front-facing Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Front-facing Camera Replacement: passo 2, imagem 1 %32 Moto G4 Front-facing Camera Replacement: passo 2, imagem 2 %32
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Front-facing Camera Replacement: passo 3, imagem 1 %32 Moto G4 Front-facing Camera Replacement: passo 3, imagem 2 %32 Moto G4 Front-facing Camera Replacement: passo 3, imagem 3 %32
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Front-facing Camera Replacement: passo 4, imagem 1 %32 Moto G4 Front-facing Camera Replacement: passo 4, imagem 2 %32
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Front-facing Camera Replacement, Midframe: passo 5, imagem 1 %32 Moto G4 Front-facing Camera Replacement, Midframe: passo 5, imagem 2 %32 Moto G4 Front-facing Camera Replacement, Midframe: passo 5, imagem 3 %32
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Front-facing Camera Replacement: passo 6, imagem 1 %32 Moto G4 Front-facing Camera Replacement: passo 6, imagem 2 %32
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Front-facing Camera Replacement: passo 7, imagem 1 %32
    • Remove the rubber cover.
  8. Moto G4 Front-facing Camera Replacement: passo 8, imagem 1 %32 Moto G4 Front-facing Camera Replacement: passo 8, imagem 2 %32
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Front-facing Camera Replacement: passo 9, imagem 1 %32
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Front-facing Camera Replacement: passo 10, imagem 1 %32
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Front-facing Camera Replacement: passo 11, imagem 1 %32
    • Remove the midframe.
  12. Moto G4 Front-facing Camera Replacement, Battery Disconnection: passo 12, imagem 1 %32 Moto G4 Front-facing Camera Replacement, Battery Disconnection: passo 12, imagem 2 %32
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  13. Moto G4 Front-facing Camera Replacement, Front-facing Camera: passo 13, imagem 1 %32 Moto G4 Front-facing Camera Replacement, Front-facing Camera: passo 13, imagem 2 %32 Moto G4 Front-facing Camera Replacement, Front-facing Camera: passo 13, imagem 3 %32
    • It's not necessary to remove the battery in order to replace the front-facing camera; you can safely ignore the fact that the battery is missing in these images.
    • Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame.
    • Peel back and remove any tape covering the front-facing camera's flex cable connector.
    • Pry up with your spudger or other ESD-safe tool to flip open the locking flap on the front-facing camera's ZIF connector.
    • Gently pull the camera's flex cable free from the ZIF socket.
  14. Moto G4 Front-facing Camera Replacement: passo 14, imagem 1 %32
    • Remove the front camera.
Conclusão
Kieran Basheer
Membro desde: 02/12/18
122 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S15-G3, Boczar Spring 2018 Membro de USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 Membros
Autoria de 12 guias
1Comentário do guia
Merci pour ce tutoriel très simple qui m'a permis (à 76 ans) de facilement remplacer la camera avant qui ne fonctionnait plus suite à une chute.... Prix de la camera trouvée sur Ebay 6€
Jean-Charles
facebook - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 903
