Introdução
If your Motorola Moto G4 is no longer charging, replacing the MicroUSB port may be needed. Follow this guide to do the replacement yourself.
Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate. Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
  • Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
Adicionar comentário
Remove the nineteen 3mm screws with a T4 screwdriver. Lift the back panel off. Lift the back panel off.
  • Remove the nineteen 3mm screws with a T4 screwdriver.
  • Lift the back panel off.
My phone had Torx T3 screws, not T4.
Camera connector needs to be disconnected before removing back panel. Remove sim card shaped rubber panel first, then lift off metal rectangular connector below it.
Kenny W - Responder
Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers. Disconnect the wire.
  • Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers.
  • Disconnect the wire.
  • Lift the battery out.
  • The battery is glued down so you will have to use some force to pull it out.
  • Be careful not to pull it too hard it could bend the battery.
Use the tweezers, pull up on the clasp that is holding the motherboard down. Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
  • Use the tweezers, pull up on the clasp that is holding the motherboard down.
    • Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack
  • Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
my headphone connecter broke off because instructions unclear…
kevin9mai - Responder
Use the tweezers pull up on the three corners of the motherboard until it comes out. Use the tweezers pull up on the three corners of the motherboard until it comes out.
  • Use the tweezers pull up on the three corners of the motherboard until it comes out.
The charging port is soldered to the motherboard, to remove desolder and remove port.
  • The charging port is soldered to the motherboard, to remove desolder and remove port.
  • New charging port will have to be soldered back into place.
Conclusão
Giuseppe Spano
101 reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S15-G3, Boczar Spring 2018 Membro de USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 Membros
5 Guides authored
It is said at the beginning of the guide that no parts are needed. However, if the charging port is damaged and a new micro USB port is required, there are several options available of micro USB ports. Would it be possible that you recommend what to buy before opening up the device for this process?
Carlos Estevez - Responder
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 99
Todo: 206
