Ir para o conteúdo principal
Moto C Plus Motherboard Assembly Replacement
O que você precisa
  1. Moto C Plus Motherboard Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement, Back Cover: passo 1, imagem 2 %32 Moto C Plus Motherboard Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Motherboard Assembly Replacement: passo 2, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 2, imagem 2 %32
    • Lift the phone out of the back cover.
  3. Moto C Plus Motherboard Assembly Replacement, Battery: passo 3, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement, Battery: passo 3, imagem 2 %32 Moto C Plus Motherboard Assembly Replacement, Battery: passo 3, imagem 3 %32
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Moto C Plus Motherboard Assembly Replacement, Motherboard Cover: passo 4, imagem 1 %32
    • Remove the five 3.1 mm long Phillips #00 screws.
  5. Moto C Plus Motherboard Assembly Replacement: passo 5, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 5, imagem 2 %32 Moto C Plus Motherboard Assembly Replacement: passo 5, imagem 3 %32
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  6. Moto C Plus Motherboard Assembly Replacement: passo 6, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 6, imagem 2 %32
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  7. Moto C Plus Motherboard Assembly Replacement, Motherboard Assembly: passo 7, imagem 1 %32
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
  8. Moto C Plus Motherboard Assembly Replacement: passo 8, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 8, imagem 2 %32
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
  9. Moto C Plus Motherboard Assembly Replacement: passo 9, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  10. Moto C Plus Motherboard Assembly Replacement: passo 10, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 10, imagem 2 %32
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  11. Moto C Plus Motherboard Assembly Replacement: passo 11, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 11, imagem 2 %32
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  12. Moto C Plus Motherboard Assembly Replacement: passo 12, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 12, imagem 2 %32
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  13. Moto C Plus Motherboard Assembly Replacement: passo 13, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 13, imagem 2 %32
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  14. Moto C Plus Motherboard Assembly Replacement: passo 14, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 14, imagem 2 %32
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  15. Moto C Plus Motherboard Assembly Replacement: passo 15, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 15, imagem 2 %32
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  16. Moto C Plus Motherboard Assembly Replacement: passo 16, imagem 1 %32 Moto C Plus Motherboard Assembly Replacement: passo 16, imagem 2 %32
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  17. Moto C Plus Motherboard Assembly Replacement: passo 17, imagem 1 %32
    • Remove the motherboard.
Conclusão
9 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
247.115 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.719 guias
1Comentário do guia
roderyjose9@gmail como hago para encender este mismo teléfono sin el botón de encendido
Rodery Josè Garcia Hidalgo - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 6,918
