O que você precisa
Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Use a Phillips # 1 screwdriver to screw that holds the CD / DVD drive in place.
Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
Insert a standard screwdriver into the slot in the cover above the keyboard.
Lift the cover with the usual care.
For reassembly, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
