Introdução
As you may already know, the Motex E101 is a popular label maker that is commonly used for home and office labeling needs. While the device is durable and reliable, replacing the label tape spool can be a tricky task, if the current spool is not yet empty. However, with the right tricks, you can easily replace the label tape spool of your Motex E101 label maker and continue creating labels without any interruption.
O que você precisa
Quase terminado!
Conclusão
