Introdução
The daisy wheel is a critical component of this label maker, as it is responsible for creating the raised letters and numbers on your labels. Over time, the daisy wheel may become worn or damaged, which can affect the quality of your labels, or you may simply want to use a different character set to customize your labels. Fortunately, both replacing or just swapping the daisy wheel is a relatively simple process that doesn't even requre any tools. In this guide, we'll walk you through the steps involved in replacing or swapping the daisy wheel on your Motex E101 label maker, so you can get back to creating clear and professional-looking labels in your desired character set.
O que você precisa
