Introdução
If your Moosoo XL-618A vacuum is not turning on, you may have an issue with the motherboard. The motherboard is where the technological components of the vacuum come together and are powered. If you find that your vacuum is having technological issues, follow this guide on how to replace it.
O que você precisa
Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
Quase terminado!
Conclusão
