Ir para o conteúdo principal
Montgomery Ward GEN-39500 Subwoofer Replacement
O que você precisa
  1. Montgomery Ward GEN-39500 Subwoofer Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Subwoofer Replacement: passo 2, imagem 1 %32
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Subwoofer Replacement: passo 3, imagem 1 %32 Montgomery Ward GEN-39500 Subwoofer Replacement: passo 3, imagem 2 %32
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: passo 4, imagem 1 %32 Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: passo 4, imagem 2 %32
    • Unsolder the wires leading to and from the subwoofer.
  5. Montgomery Ward GEN-39500 Subwoofer Replacement: passo 5, imagem 1 %32
    • Unscrew the four 12.5 mm Phillips screws holding the subwoofer in place.
    • One of the screws holds down a metal cable organizer. For better cable organization after reassembly keep track of this organizer.
  6. Montgomery Ward GEN-39500 Subwoofer Replacement: passo 6, imagem 1 %32
    • Remove the subwoofer.
    • The process is the same for both sides.
Conclusão
Dustin Platt
Membro desde: 04/01/15
931 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membro de Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Membros
Autoria de 13 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 159
