Ir para o conteúdo principal
Monteren en demonteren van een tablet
O que você precisa
  1. Monteren en demonteren van een tablet, Monteren en demonteren van een tablet: passo 1, imagem 1 %32
    • The hull seen from the front.
  2. Monteren en demonteren van een tablet: passo 2, imagem 1 %32
    • The case seen from the back, with the jacks where to connect your handsets
  3. Monteren en demonteren van een tablet: passo 3, imagem 1 %32
    • Enough to redo a shell in case of problems, but without the feet.
    • The T14 snake-eyes tip to disassemble the facade.
    • Collars to block the jacks of your handsets under the shell.
    • Replacement snake eyes M6 screws, M6 inserts to remake a shell
  4. Monteren en demonteren van een tablet: passo 4, imagem 1 %32
    • Use the tip to disassemble the screws.
    • DO IT MANUALLY!!!
    • Not to the screwdriver, because it will rip. And the tip will damage the facade.
  5. Monteren en demonteren van een tablet: passo 5, imagem 1 %32
    • To block the jacks of the handsets: make a knot on the collar.
    • Thus, users will not be able to disconnect the handsets
  6. Monteren en demonteren van een tablet: passo 6, imagem 1 %32
    • If you want to redo a shell:
    • You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
    • Take the model delivered as an example
  7. Monteren en demonteren van een tablet: passo 7, imagem 1 %32
    • To change the content of the micro SD card:
    • You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
    • Create a file named: sexbreizh.avi
    • AVI container, mp3 audio codec, xvid video codec
    • Audio bitrate: 44100
    • Video rate: 8000
Conclusão
Om het apparaat weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
5 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
AFPD Conception
Membro desde: 04/01/14
196 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 41
Duração total: 779
