Ir para o conteúdo principal
Monster Soundstage S2 Speaker Grille Replacement
O que você precisa
  1. Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: passo 1, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Speaker Grille Replacement: passo 2, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 2, imagem 2 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 2, imagem 3 %32
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Speaker Grille Replacement: passo 3, imagem 1 %32
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Speaker Grille Replacement: passo 4, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 4, imagem 2 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Speaker Grille Replacement: passo 5, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 5, imagem 2 %32
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Speaker Grille Replacement: passo 6, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 6, imagem 2 %32
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Speaker Grille Replacement: passo 7, imagem 1 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 7, imagem 2 %32 Monster Soundstage S2 Speaker Grille Replacement: passo 7, imagem 3 %32
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Speaker Grille Replacement: passo 8, imagem 1 %32
    • Remove the front speaker grille.
Conclusão
3 outras pessoas executaram este guia.
Shaw Hughes
Membro desde: 01/30/17
831 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 21-5, Maness Winter 2017 Membro de Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 453
