Ir para o conteúdo principal
Monster Soundstage S2 Rear Speaker Replacement
O que você precisa
  1. Monster Soundstage S2 Rear Speaker Replacement, Speaker Grille: passo 1, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Rear Speaker Replacement: passo 2, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 2, imagem 2 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 2, imagem 3 %32
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Rear Speaker Replacement: passo 3, imagem 1 %32
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Rear Speaker Replacement: passo 4, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 4, imagem 2 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Rear Speaker Replacement: passo 5, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 5, imagem 2 %32
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Rear Speaker Replacement: passo 6, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 6, imagem 2 %32
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Rear Speaker Replacement: passo 7, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 7, imagem 2 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 7, imagem 3 %32
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Rear Speaker Replacement: passo 8, imagem 1 %32
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: passo 9, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: passo 9, imagem 2 %32 Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: passo 9, imagem 3 %32
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Rear Speaker Replacement: passo 10, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 10, imagem 2 %32
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Rear Speaker Replacement: passo 11, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 11, imagem 2 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 11, imagem 3 %32
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Rear Speaker Replacement, Front Panel: passo 12, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement, Front Panel: passo 12, imagem 2 %32
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Rear Speaker Replacement: passo 13, imagem 1 %32
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Rear Speaker Replacement: passo 14, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 14, imagem 2 %32
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Rear Speaker Replacement: passo 15, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement: passo 15, imagem 2 %32
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
  16. Monster Soundstage S2 Rear Speaker Replacement, Rear Speaker: passo 16, imagem 1 %32 Monster Soundstage S2 Rear Speaker Replacement, Rear Speaker: passo 16, imagem 2 %32
    • Remove the four 10mm screws that secure the rear speaker with a TR 10 driver.
    • Remove the rear speaker from the housing.
    • Be careful to not stress or damage the two wires that are connected to the driver.
  17. Monster Soundstage S2 Rear Speaker Replacement: passo 17, imagem 1 %32
    • Carefully but firmly unplug the two wires from the driver.
    • Remove the rear speaker.
Conclusão
Shaw Hughes
Membro desde: 01/30/17
831 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 21-5, Maness Winter 2017 Membro de Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 331
