Ir para o conteúdo principal
Monster SoundStage S1 Mini Speaker Replacement
O que você precisa
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: passo 1, imagem 1 %32 Monster SoundStage S1 Mini Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: passo 2, imagem 1 %32 Monster SoundStage S1 Mini Speaker Replacement: passo 2, imagem 2 %32
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: passo 3, imagem 1 %32
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: passo 4, imagem 1 %32 Monster SoundStage S1 Mini Speaker Replacement: passo 4, imagem 2 %32 Monster SoundStage S1 Mini Speaker Replacement: passo 4, imagem 3 %32
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: passo 5, imagem 1 %32 Monster SoundStage S1 Mini Speaker Replacement: passo 5, imagem 2 %32
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: passo 6, imagem 1 %32 Monster SoundStage S1 Mini Speaker Replacement: passo 6, imagem 2 %32
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
CSU Fullerton, Team 2-6, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 484
