Ir para o conteúdo principal
Moen Posi-Temp Cartridge Part #1112b Replacement
O que você precisa
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: passo 1, imagem 1 %32
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 2, imagem 1 %32
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 3, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 3, imagem 2 %32
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 4, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 4, imagem 2 %32
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 5, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 5, imagem 2 %32
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 6, imagem 1 %32
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, imagem 2 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 7, imagem 3 %32
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, imagem 2 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 8, imagem 3 %32
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, imagem 2 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 9, imagem 3 %32
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, imagem 2 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 10, imagem 3 %32
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 11, imagem 1 %32 Moen Posi-Temp Cartridge Part #1112b Replacement: passo 11, imagem 2 %32
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: passo 12, imagem 1 %32
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
Conclusão
John Mendoza
Membro desde: 09/17/20
205 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,409
