Ir para o conteúdo principal
Modal Rechargeable Wine Opener Power Button Replacement
O que você precisa
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: passo 1, imagem 1 %32
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: passo 2, imagem 1 %32
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: passo 3, imagem 1 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 3, imagem 2 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 3, imagem 3 %32
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: passo 4, imagem 1 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 4, imagem 2 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 4, imagem 3 %32
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: passo 5, imagem 1 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 5, imagem 2 %32 Modal Rechargeable Wine Opener Power Button Replacement: passo 5, imagem 3 %32
    • Remove the malfunctioning buttons from the plastic frame.
Conclusão
Lauren Spicher
Membro desde: 02/15/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-4, Remmell Spring 2017 Membro de USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
Membros da 4
1 Guia de autoria
4 comentários
where do you by the replacement switch?
Stan Okumura - Responder
are there any posts for fixing the usb charging port?
Cristian Sanabria - Responder
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Responder
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 57
Duração total: 8,737
