Ir para o conteúdo principal
Modal MD-SPBT01 Speaker Wiring Replacement
O que você precisa
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: passo 1, imagem 1 %32 Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: passo 1, imagem 2 %32
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: passo 2, imagem 1 %32
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: passo 3, imagem 1 %32
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: passo 4, imagem 1 %32
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: passo 5, imagem 1 %32
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: passo 6, imagem 1 %32 Modal MD-SPBT01 Speaker Wiring Replacement: passo 6, imagem 2 %32
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
Conclusão
Nathan Hall
Membro desde: 10/13/15
258 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 494
