Introdução
Follow this guide to remove and replace a faulty electric motor in a Mk Diamond MK660 Wet Saw.
The replacement part is 154292.
O que você precisa
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
Pull the entire cutting head straight off the shaft holding it in place.
Remove the eight Phillips #2 screws on the underside of the cutting head.
Remove the Phillips #2 screw holding the ground wires to the chassis.
Loosen the wires from each other.
3 outras pessoas executaram este guia.
