Ir para o conteúdo principal
Miyoo Mini Plus Face Buttons Replacement
O que você precisa
  1. Miyoo Mini Plus Face Buttons Replacement, Face Buttons: passo 1, imagem 1 %32 Miyoo Mini Plus Face Buttons Replacement, Face Buttons: passo 1, imagem 2 %32
    • Place the device face down on your work surface.
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  2. Miyoo Mini Plus Face Buttons Replacement: passo 2, imagem 1 %32
    • Remove the battery cover.
    • The battery plate can be tough, but using too much force can damage it.
  3. Miyoo Mini Plus Face Buttons Replacement: passo 3, imagem 1 %32
    • Carefully lift the battery from socket, but do not pull on the connection. The battery will still be connected to the console.
    • To remove the battery, follow the wires to the connecter slot and carefully pull out the connection directly from the socket.
    • Removing the battery from the connections can be difficult. DO NOT PULL ON THE WIRES. Pulling on the wires can damage the wires on the battery. It is recommended you use a thin, non-sharp object to pry the connection from the socket.
  4. Miyoo Mini Plus Face Buttons Replacement: passo 4, imagem 1 %32
    • Remove the two Phillips screws to inside the battery compartment.
  5. Miyoo Mini Plus Face Buttons Replacement: passo 5, imagem 1 %32 Miyoo Mini Plus Face Buttons Replacement: passo 5, imagem 2 %32
    • Insert a thin prying tool in the seam and pry around the perimeter until the case separates.
    • Using too much force can break the clips on the sides of console. Sometime separating the clips can be difficult, but using different angles can help instead of using more force.
  6. Miyoo Mini Plus Face Buttons Replacement: passo 6, imagem 1 %32
    • Remove the two Phillips screws on the motherboard.
  7. Miyoo Mini Plus Face Buttons Replacement: passo 7, imagem 1 %32 Miyoo Mini Plus Face Buttons Replacement: passo 7, imagem 2 %32
    • Remove the ribbon cable from the console. To do this, there is a small black clip that locks the ribbon cable in place. To unlock this clip, simply flip the black clip vertically.
    • Pull the cable to the left to remove it from the socket.
    • Do not pull on the ribbon cable with too much force as it can cause permanent damage to the console. When the black clip is unlocked, the ribbon cable should slide out easily.
  8. Miyoo Mini Plus Face Buttons Replacement: passo 8, imagem 1 %32 Miyoo Mini Plus Face Buttons Replacement: passo 8, imagem 2 %32 Miyoo Mini Plus Face Buttons Replacement: passo 8, imagem 3 %32
    • Remove the motherboard from the front housing. There may be some adhesive preventing you from pulling the motherboard out, but you can still remove the board by carefully pulling from the edges.
    • When removing the board, the power button and the volume buttons can fall out as it is not directly attached to any of the plates. To prevent losing these pieces, you can simply take these pieces out and store them safely before pulling out the motherboard.
  9. Miyoo Mini Plus Face Buttons Replacement: passo 9, imagem 1 %32 Miyoo Mini Plus Face Buttons Replacement: passo 9, imagem 2 %32 Miyoo Mini Plus Face Buttons Replacement: passo 9, imagem 3 %32
    • You can now see the backside of the face buttons. Pull out the center, start, and select buttons as they fall out easily and replace them with new buttons.
    • If you wish to replace the directional and action buttons, remove the silicon covers. Once they are removed, the buttons will easily fall out and are ready to be replaced with the new buttons.
Conclusão
3 outras pessoas executaram este guia.
Equipe
CSU Los Angeles, Team 8-8, Ribeiro Fall 2023 Membro de CSU Los Angeles, Team 8-8, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S8G8
3 Membros
Autoria de 2 guias
1Comentário do guia
The #00 Philips bit was too small for the screws on my device, and I found that the #1 Philips bit was the correct size. Also worth mentioning that the two motherboard screws were eventually eliminated from newer devices, so some users may not find screws in those two holes.
Tyler Brooks - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 96
Ao todo: 3,248
