Ir para o conteúdo principal
Mitsubishi T200 Screen Replacement
O que você precisa
  1. Mitsubishi T200 Screen Replacement, Screen: passo 1, imagem 1 %32 Mitsubishi T200 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: passo 2, imagem 1 %32
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: passo 3, imagem 1 %32
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: passo 4, imagem 1 %32
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: passo 5, imagem 1 %32 Mitsubishi T200 Screen Replacement: passo 5, imagem 2 %32
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: passo 6, imagem 1 %32 Mitsubishi T200 Screen Replacement: passo 6, imagem 2 %32
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: passo 7, imagem 1 %32 Mitsubishi T200 Screen Replacement: passo 7, imagem 2 %32
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: passo 8, imagem 1 %32
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: passo 9, imagem 1 %32
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: passo 10, imagem 1 %32
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: passo 11, imagem 1 %32
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: passo 12, imagem 1 %32
    • Firmly replace screws into the backing.
Linha de Chegada
Taylor Lewis
Membro desde: 02/13/14
14 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Meza Spring 2014 Membro de Ohio State, Team 1-5, Meza Spring 2014
OSU-MEZA-S14S1G5
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 801
