Ir para o conteúdo principal
Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale)
O que você precisa
  1. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Identify your Revision: passo 1, imagem 1 %32
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • In this case the Version Number is W-12.
  2. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Download the Image File: passo 2, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Download the Image File: passo 2, imagem 2 %32
    • You can download the image file here: link
    • Press on ISO IMAGE.
    • Download the MAPCARD_####_2023-A_EU.img file containing the version number of your device in its title.
    • MMCS E-11 and E-12 are analogues of W-13.
  3. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Insert the SD Card: passo 3, imagem 1 %32
    • The SD Card has to be a 16GB SDHC card with at least 15.718.400.000 Bytes and 30.700.000 Logic Sectors.
    • If the SD Card you have is a bit too small, but you have larger one on hand, you can also just flash to the larger one, format the smaller one to exFAT at 512 Bytes per sector and copy all the files over from the larger one. This might lead to some instability, but still works.
    • Insert the SD Card into your PC.
  4. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Launch Etcher: passo 4, imagem 1 %32
    • Launch balenaEtcher.
    • Since we are using a standard .img-file, you can also use any other program capable of flashing image files, though this guide will only cover the process using Balena Etcher.
  5. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the file to flash: passo 5, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the file to flash: passo 5, imagem 2 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the file to flash: passo 5, imagem 3 %32
    • Press the Flash from file-button.
    • Select the file we downloaded in step 2.
  6. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the SD Card to write to: passo 6, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the SD Card to write to: passo 6, imagem 2 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Select the SD Card to write to: passo 6, imagem 3 %32
    • Press the Select target-button.
    • Select the SD card you want to write to.
    • Press the Select-button.
  7. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Flash the file: passo 7, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Flash the file: passo 7, imagem 2 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Flash the file: passo 7, imagem 3 %32
    • Press the Flash!-button.
    • Wait until the program finishes writing to the card.
    • Remove the SD card from the computer once the process is finished.
  8. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Flip up the Display: passo 8, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Flip up the Display: passo 8, imagem 2 %32
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  9. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Swap the SD Card: passo 9, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Swap the SD Card: passo 9, imagem 2 %32
    • Swap the SD Card with the one already installed in the MAP-Slot.
    • Close the display by pressing the OPEN-Button again.
    • If the car accepts the SD Card it will now be permanently paired to the MMCS and no longer work with any other car or show up on a computer.
    • If the firmware on the SD Card is newer than the version already installed the Unit will ask you if you want to update. Press the Update-Button on the screen to proceed.
    • If you were already on the newest firmware version, the car will normally at most run a short update sequence after you restart the car.
    • Do not turn off the ignition while the update is running!
    • If you are switching from the Russian to the European interface or vice versa, the unit might tell you that it can’t read the Map card data. The following steps will only apply if you are encountering this problem.
  10. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Enter the Service Menu: passo 11, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Enter the Service Menu: passo 11, imagem 2 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Enter the Service Menu: passo 11, imagem 3 %32
    • Enter the Service Menu by pressing and holding the SETTINGS and MAP-Buttons (for W-16 & W-17 INFO/SET and SEEK) for 4 seconds.
  11. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Navigate the Service Menu: passo 12, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Navigate the Service Menu: passo 12, imagem 2 %32
    • Navigate to Versions Indication.
    • Long-press Navi (Application) for 4 seconds.
  12. Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Update the Unit: passo 13, imagem 1 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Update the Unit: passo 13, imagem 2 %32 Mitsubishi MMCS NR-242 Map Data Card Update (ISO Image, European locale), Update the Unit: passo 13, imagem 3 %32
    • Press Update from Map Card.
    • Confirm by pressing on Update.
    • The Unit will now start the update process. In this process it will reboot twice and reset itself back to factory settings.
    • Do not turn off the car while the update is running!
Conclusão
Make sure you keep the old SD Card as a backup, just in case anything ever happens to the new one.
Uma outra pessoa concluiu este guia.
Sebastian
Membro desde: 08/19/18
28.112 Reputação
Autoria de 71 guias
Equipe
German Translators Membro de German Translators
Community
35 Membros
Autoria de 1.212 guias
10 comentários
Bei mir klappt es leider nicht.
Haber ein W15 Modell, habe das ISO Image auf eine Micro SD + SD Adapter geflasht.
Beim Einlegen erscheint die Meldung "Speicherkrte kann nicht gelesen werden. Überprüfen sie die Karte".
Habe bereits mit FAT32, NTFS, extFat formartiert.
Was mache ich falsch?
Da Dre - Responder
Das ist schwer zu sagen, das Gerät kann etwas wählerisch mit Karten und USB Sticks sein... Hast du schon Mal versucht eine Karte auf exfat zu formatieren und die Dateien aus der ISO Datei zu Copy Pasten? Ansonsten könntest du auch Mal den "alten" Prozess mit Winhex ausprobieren, Winhex ist allerdings keine Freeware.
Alfred Kwak -
Danke für die schnelle Antwort.
Ich habe schon eine andere Speicherkarte probiert...auch formatiert mit extFat.
Mit Winhex bin ich leider auch gescheitert, nachdem ich die Map Datei geschrieben habe, müssen die Systemdaten geschrieben werden.
Hier kommt aber die Meldung, dass diese nicht geschrieben werden kann da Fehler auf der Speicherkarte erkannt worden sind.
Da Dre - Responder
Hast du es mal mit einer neuen Karte von einem anderen Hersteller versucht? Nicht alle 16gb Karten sind gleich. Manche sind minimal kleiner als andere, was zu Problemen führen kann. SanDisk Karten z.B. funktionieren meistens sehr gut. SwissBit Karten sollten auch funktionieren, aber ich hab sie noch nicht im Auto getestet. Hama Karten sind zu klein, man kann sie aber auf exfat formatieren und die Dateien manuell aus der ISO Datei rüberkopieren.
Alfred Kwak -
Ich gebe auf....habe es nun noch mit einer neuen SD Karte probiert. Auch hier der beschriebene Fehler.
Hab auch probiert die ISO zu mappen und die Daten manuell auf die Speicherkarte zu kopieren.
Da Dre - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 119
Últimos 30 dias: 344
Ao todo: 4,357
