Ir para o conteúdo principal
Mitsubishi Electric DD-6040 Power Button Replacement
O que você precisa
  1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: passo 1, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: passo 1, imagem 2 %32 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Unplug your DVD player prior to working on the device.
    • Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
  2. Mitsubishi Electric DD-6040 Power Button Replacement: passo 2, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 2, imagem 2 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 2, imagem 3 %32
    • Once the screws are removed, slide back and remove the cover.
  3. Mitsubishi Electric DD-6040 Power Button Replacement: passo 3, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 3, imagem 2 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 3, imagem 3 %32
    • Gently pull out the green circuit board.
    • Be very careful, as circuit boards can be quite fragile.
  4. Mitsubishi Electric DD-6040 Power Button Replacement: passo 4, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 4, imagem 2 %32
    • Flip the DVD player over and pull up on the clip.
  5. Mitsubishi Electric DD-6040 Power Button Replacement: passo 5, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 5, imagem 2 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 5, imagem 3 %32
    • Once the clip is unlatched disconnect the corner tabs.
    • Reorient and unlatch the tabs inside the device.
    • Remove the faceplate.
  6. Mitsubishi Electric DD-6040 Power Button Replacement: passo 6, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 6, imagem 2 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 6, imagem 3 %32
    • Pull on the old power button to remove it.
  7. Mitsubishi Electric DD-6040 Power Button Replacement: passo 7, imagem 1 %32 Mitsubishi Electric DD-6040 Power Button Replacement: passo 7, imagem 2 %32
    • Adjust and push the new button into place.
Conclusão
To reassemble your device, follow these steps in reverse order.
Uma outra pessoa concluiu este guia.
Usha Alexis
Membro desde: 01/12/20
199 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 380
