Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Lift the black cover off. Remove all 4 Phillips #2 screws. Remove all 4 Phillips #2 screws.
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Remove the two 24mm Phillips #2 screws.
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Lift the back and pry the back off. The panel is held in with clips on the side. It needs a lot of force the take it off. The panel is held in with clips on the side. It needs a lot of force the take it off.
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Remove the four 5mm nut screws. Remove the four 5mm nut screws.
    • Remove the four 5mm nut screws.
  5. Remove the seven Phillips #1 screws. Remove the seven Phillips #1 screws.
    • Remove the seven Phillips #1 screws.
  6. Remove all the cables. Remove all the cables. Remove all the cables.
    • Remove all the cables.
  7. Remove the four screws. Pull the motherboard up and off. Pull the motherboard up and off.
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Now you can replace it with a new one.
    • Now you can replace it with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Padraic Hoselton
Membro desde: 22/08/2017
3.609 Reputação
13 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
295 Membros
963 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 70
