Ir para o conteúdo principal
MistAire Humidifier Cap Spring Replacement
O que você precisa
  1. MistAire Humidifier Cap Spring Replacement, Cap Spring: passo 1, imagem 1 %32 MistAire Humidifier Cap Spring Replacement, Cap Spring: passo 1, imagem 2 %32
    • Lift the blue tank off of the base of the humidifier.
    • The two parts are not attached or snapped together, so they should separate easily.
    Pergunte ao FixBot
    Comentar
  2. MistAire Humidifier Cap Spring Replacement: passo 2, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 2, imagem 2 %32 MistAire Humidifier Cap Spring Replacement: passo 2, imagem 3 %32
    • Turn the tank upside down.
    • Turn the round cap counterclockwise to completely unscrew it.
    Pergunte ao FixBot
    Comentar
  3. MistAire Humidifier Cap Spring Replacement: passo 3, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 3, imagem 2 %32
    • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
    • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
    Pergunte ao FixBot
    Comentar
  4. MistAire Humidifier Cap Spring Replacement: passo 4, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 4, imagem 2 %32 MistAire Humidifier Cap Spring Replacement: passo 4, imagem 3 %32
    • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
    Pergunte ao FixBot
    Comentar
  5. MistAire Humidifier Cap Spring Replacement: passo 5, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 5, imagem 2 %32
    • Once the ring is off, pull the rod and spring out from the center of the cap.
    Pergunte ao FixBot
    Comentar
  6. MistAire Humidifier Cap Spring Replacement: passo 6, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 6, imagem 2 %32
    • Slide the broken spring off of the rod.
    • The spring should come off easily.
    Pergunte ao FixBot
    Comentar
  7. MistAire Humidifier Cap Spring Replacement: passo 7, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 7, imagem 2 %32
    • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
    • Ensure the narrower end of the cone-shaped spring goes first.
    Pergunte ao FixBot
    Comentar
  8. MistAire Humidifier Cap Spring Replacement: passo 8, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 8, imagem 2 %32
    • Pinch the spring gently to secure it around the rod.
    • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
    Pergunte ao FixBot
    Comentar
  9. MistAire Humidifier Cap Spring Replacement: passo 9, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 9, imagem 2 %32 MistAire Humidifier Cap Spring Replacement: passo 9, imagem 3 %32
    • Push the small blue ring back onto the pointed end of the rod.
    • You should hear a snap when it’s secured.
    Pergunte ao FixBot
    Comentar
  10. MistAire Humidifier Cap Spring Replacement: passo 10, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 10, imagem 2 %32 MistAire Humidifier Cap Spring Replacement: passo 10, imagem 3 %32
    • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
    Pergunte ao FixBot
    Comentar
  11. MistAire Humidifier Cap Spring Replacement: passo 11, imagem 1 %32 MistAire Humidifier Cap Spring Replacement: passo 11, imagem 2 %32 MistAire Humidifier Cap Spring Replacement: passo 11, imagem 3 %32
    • Place the tank back onto the humidifier base.
    • You have now successfully replaced the spring in the MistAire Humidifier!
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Abby
Membro desde: 01/31/24
193 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-1, Andersen Winter 2024 Membro de UC Davis, Team 1-1, Andersen Winter 2024
UCD-ANDERSEN-W24S1G1
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 33
Últimos 30 dias: 140
Ao todo: 1,511
