Ir para o conteúdo principal
Misfit Vapor Battery Replacement
O que você precisa
  1. Misfit Vapor Battery Replacement, Watch Strap: passo 1, imagem 1 %32 Misfit Vapor Battery Replacement, Watch Strap: passo 1, imagem 2 %32
    • Using your fingers, press down on the rubber circles to unbuckle the strap from itself.
    • Once you have removed two of the rubber circles from from a side you will be able to unbuckle the strap on that side.
  2. Misfit Vapor Battery Replacement, Battery: passo 2, imagem 1 %32
    • Hold the side power button to ensure the watch is completely shut down.
  3. Misfit Vapor Battery Replacement: passo 3, imagem 1 %32
    • To access the battery compartment use the Jaxa-style wrench tool. Secure the midframe while you pop up the back.
    • This will require an extremely high amount of force as there is a rubber seal and the fit is tight.
  4. Misfit Vapor Battery Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the battery cover by carefully using tweezers or the iFixit opening tool.
  5. Misfit Vapor Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the small ribbon cable connector.
    • Remove the battery from the watch.
Conclusão
Uma outra pessoa concluiu este guia.
Alan Castro
Membro desde: 03/01/23
109 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 839
