Ir para o conteúdo principal
Mio Alpha 2 Charging Pins Replacement
O que você precisa
  1. Mio Alpha 2 Charging Pins Replacement, Charging Pins: passo 1, imagem 1 %32
    • Remove the four 6.7mm JIS #00 screws from the back cover.
  2. Mio Alpha 2 Charging Pins Replacement: passo 2, imagem 1 %32 Mio Alpha 2 Charging Pins Replacement: passo 2, imagem 2 %32
    • Remove the gold coils from the bottom of the pin. Remove the washer from the pin with the spudger.
  3. Mio Alpha 2 Charging Pins Replacement: passo 3, imagem 1 %32 Mio Alpha 2 Charging Pins Replacement: passo 3, imagem 2 %32
    • Pop the pins out one at a time using the spudger.
Linha de Chegada
Stefan Tracogna
Membro desde: 11/27/17
1 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S22-G3, Bayer Fall 2017 Membro de IUPUI, Team S22-G3, Bayer Fall 2017
IUPUI-BAYER-F17S22G3
4 Membros
Autoria de 2 guias
2Comentários do guia
How are you "replacing" a part with no parts required.... would be super cool to have the part number or any information on those pins.
mattgrimshaw91 - Responder
How do I charge it without a charger? I just got this watch uncharged and it didn't come with a charger.
Leslye - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 1,036
