Ir para o conteúdo principal
Minolta QTsi Maxxum Lens Replacement
O que você precisa
  1. Minolta QTsi Maxxum Lens Replacement, Lens: passo 1, imagem 1 %32 Minolta QTsi Maxxum Lens Replacement, Lens: passo 1, imagem 2 %32
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: passo 2, imagem 1 %32
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: passo 3, imagem 1 %32 Minolta QTsi Maxxum Lens Replacement: passo 3, imagem 2 %32
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
Conclusão
Jordan Ellery
Membro desde: 10/10/16
388 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 592
