Ir para o conteúdo principal
Minolta Maxxum STsi Clock Battery Replacement
O que você precisa
  1. Minolta Maxxum STsi Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32
    • Press up firmly on the back-cover release on the right side of the camera to release the back panel.
  2. Minolta Maxxum STsi Clock Battery Replacement: passo 2, imagem 1 %32
    • Use a coin to twist open the battery compartment (twist counterclockwise).
  3. Minolta Maxxum STsi Clock Battery Replacement: passo 3, imagem 1 %32
    • Use tweezers to lift off the battery compartment cover.
  4. Minolta Maxxum STsi Clock Battery Replacement: passo 4, imagem 1 %32
    • Use tweezers to take out the old clock battery and replace it with a new one.
Conclusão
Conner Lawston
Membro desde: 04/21/15
219 Reputação
Autoria de 2 guias
2 comentários
Will the camera itself stop working if there is no clock battery?
Olivia Ortiz - Responder
nope. it’s don’t stop working without clock battery
Pavel Gogin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 890
