Ir para o conteúdo principal
Minolta Maxxum QTSI Tripod Mount Replacement
O que você precisa
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: passo 1, imagem 1 %32
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: passo 2, imagem 1 %32 Minolta Maxxum QTSI Tripod Mount Replacement: passo 2, imagem 2 %32
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: passo 3, imagem 1 %32
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: passo 4, imagem 1 %32 Minolta Maxxum QTSI Tripod Mount Replacement: passo 4, imagem 2 %32
    • Use the tweezers to gently remove the tripod socket, and replace it.
Conclusão
Jordan Ellery
Membro desde: 10/10/16
388 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 334
