Ir para o conteúdo principal
Minolta Dimage Xt LCD Screen Disassembly
O que você precisa
  1. Minolta Dimage Xt LCD Screen Disassembly, Casing: passo 1, imagem 1 %32 Minolta Dimage Xt LCD Screen Disassembly, Casing: passo 1, imagem 2 %32 Minolta Dimage Xt LCD Screen Disassembly, Casing: passo 1, imagem 3 %32
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt LCD Screen Disassembly: passo 2, imagem 1 %32 Minolta Dimage Xt LCD Screen Disassembly: passo 2, imagem 2 %32 Minolta Dimage Xt LCD Screen Disassembly: passo 2, imagem 3 %32
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: passo 3, imagem 1 %32
    • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
    • The screen also has a ribbon wire connected at the bottom of the screen.
  4. Minolta Dimage Xt LCD Screen Disassembly: passo 4, imagem 1 %32 Minolta Dimage Xt LCD Screen Disassembly: passo 4, imagem 2 %32
    • Detach the connector at the bottom from the LCD screen.
    • Starting from the side or a corner gently slide the spudger underneath the screen.
    • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
  5. Minolta Dimage Xt LCD Screen Disassembly: passo 5, imagem 1 %32
    • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
    • Check to make sure the wires are connected, so it will receive proper power supply.
    • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
Conclusão
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
Uma outra pessoa concluiu este guia.
Keith Sechrist
Membro desde: 03/11/13
22 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 12-4, Benson Spring 2013 Membro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
Membros da 3
Autoria de 14 guias
Um comentário
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 976
