Introdução
The flashbulb and casing are one component located at the top of the camera. A replacement will be the whole component and not each of the parts separately.
O que você precisa
Remove 2mm screws connecting the flash housing to the main components of the camera.
Conclusão
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
