Ir para o conteúdo principal
Minolta Dimage Xt Flash Capacitor Replacement
O que você precisa
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, imagem 1 %32 Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, imagem 2 %32 Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, imagem 3 %32
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: passo 2, imagem 1 %32 Minolta Dimage Xt Flash Capacitor Replacement: passo 2, imagem 2 %32 Minolta Dimage Xt Flash Capacitor Replacement: passo 2, imagem 3 %32
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: passo 3, imagem 1 %32 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: passo 3, imagem 2 %32
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Conclusão
Uma outra pessoa concluiu este guia.
Qqq
Membro desde: 03/11/13
19 Reputação
Autoria de 1 guia
Um comentário
Its a cap not a battery :D
Eigirdas Gedgaudas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 990
