Ir para o conteúdo principal
Minolta Dimage Xt Casing Replacement
O que você precisa
  1. Minolta Dimage Xt Casing Replacement, Casing: passo 1, imagem 1 %32 Minolta Dimage Xt Casing Replacement, Casing: passo 1, imagem 2 %32 Minolta Dimage Xt Casing Replacement, Casing: passo 1, imagem 3 %32
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Casing Replacement: passo 2, imagem 1 %32 Minolta Dimage Xt Casing Replacement: passo 2, imagem 2 %32 Minolta Dimage Xt Casing Replacement: passo 2, imagem 3 %32
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
Conclusão
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
Membro desde: 03/11/13
56 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 12-4, Benson Spring 2013 Membro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membros
Autoria de 14 guias
1Comentário do guia
How to reattach the ribbon????
rosybrier - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 598
