Ir para o conteúdo principal
Minolta Dimage Xt Capture Button Replacement
O que você precisa
  1. Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 1 %32 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 2 %32 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 3 %32
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 1 %32 Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 2 %32 Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 3 %32
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: passo 4, imagem 1 %32
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Conclusão
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membro desde: 03/11/13
56 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 12-4, Benson Spring 2013 Membro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 635
