Ir para o conteúdo principal
Milwaukee M18 2606-20 Gearbox Replacement
O que você precisa
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: passo 1, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: passo 1, imagem 2 %32 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: passo 1, imagem 3 %32
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Gearbox Replacement: passo 2, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 2, imagem 2 %32
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: passo 3, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 3, imagem 2 %32
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: passo 4, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 4, imagem 2 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 4, imagem 3 %32
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: passo 5, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: passo 5, imagem 2 %32
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: passo 6, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 6, imagem 2 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 6, imagem 3 %32
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: passo 7, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 7, imagem 2 %32
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: passo 8, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 8, imagem 2 %32
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: passo 9, imagem 1 %32 Milwaukee M18 2606-20 Gearbox Replacement: passo 9, imagem 2 %32
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 77
Duração total: 3,920
