Ir para o conteúdo principal
Milwaukee M12 2407-20 Speed Selector Lever Replacement
O que você precisa
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: passo 1, imagem 1 %32
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: passo 2, imagem 1 %32
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, imagem 1 %32 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, imagem 2 %32 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, imagem 3 %32
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: passo 4, imagem 1 %32
    • Use a spudger to pry the broken speed selector lever off the assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 1,556
