Introdução
This guide will walk through the steps to replace the shuttle spring plate on the Milwaukee M12 2407-20.
O que você precisa
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Use both hands to lift and remove the gear case assembly from the shell casing.
Set the gear case assembly aside.
