Ir para o conteúdo principal
Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
O que você precisa
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: passo 1, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: passo 1, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: passo 1, imagem 3 %32
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 2, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 2, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 2, imagem 3 %32
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 3, imagem 1 %32
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 4, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 4, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: passo 4, imagem 3 %32
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 756
