Ir para o conteúdo principal
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
O que você precisa
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, imagem 3 %32
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, imagem 3 %32
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, imagem 3 %32
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, imagem 3 %32
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 5, imagem 1 %32
    • Pull straight up on the field winding to remove it from the body.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 370
