Ir para o conteúdo principal
Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement
O que você precisa
  1. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: passo 1, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: passo 1, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: passo 1, imagem 3 %32
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
    • Remove (4) 5 x 14mm screws. with T-20 screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 2, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 2, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 2, imagem 3 %32
    • Hold the device so the gray gearbox assembly faces directly towards you.
    • Remove the four screws with a T-20 screwdriver.
    • After removing all screws, use a small plastic opening tool to slide the gearbox assembly forward.
  3. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 3, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 3, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 3, imagem 3 %32
    • Gently remove the upper clam shell.
    • Slide the motor and gearbox assembly out the front of the device and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The brushes may need to be compressed in order for the motor to be removed.
  4. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 4, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: passo 4, imagem 2 %32
    • Remove the brushes from the mount by pulling the brush body directly upward.
    • Disconnect the blue wire from the lower brush.
    • Disconnect the white wire from the upper brush.
    • Reconnect the wires to the new brush and replace them back into the mount.
    • The brushes may need to be compressed in order to slide the motor back into position.
Conclusão
Um comentário
Wear to find brushes for impact
Laurie Hathaway-Ashby - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 21
Duração total: 652
