Ir para o conteúdo principal
Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch
O que você precisa
  1. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, imagem 3 %32
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, imagem 3 %32
    • Remove the four screws on each corner of the gear box assembly using a T20 Torx screwdriver.
    • Use a plastic pry bar slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, imagem 3 %32
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The bushes may need to be compressed for easier removal of the motor.
  4. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, imagem 3 %32
    • Pull up on the switch to remove it from the plastic mount.
    • There are six wires connected to the back of the switch.
    • Remove the black field wire winding from the switch.
  5. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, imagem 3 %32
    • Remove the blue lower brush wire (top right) from the connector.
    • Remove the black AC power wire from the switch.
    • The wires do not need to be removed in order, but doing so helps to minimize confusion.
  6. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 6, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 6, imagem 2 %32
    • Flip the switch vertically.
    • Remove the white upper brush wire from the connector.
    • Reconnect all wires and replace the new switch back into the plastic case mount.
    • Ensure that all wires are clear of the case so that they will not be damaged on reassembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 852
