Ir para o conteúdo principal
Milwaukee Hole Hawg 1675-1 Field Replacement
O que você precisa
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: passo 1, imagem 1 %32
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 2, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 2, imagem 2 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 2, imagem 3 %32
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 3, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 3, imagem 2 %32
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: passo 4, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement, Field: passo 4, imagem 2 %32
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 5, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 5, imagem 2 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 5, imagem 3 %32
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 6, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 6, imagem 2 %32
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 7, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 7, imagem 2 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 7, imagem 3 %32
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 8, imagem 1 %32 Milwaukee Hole Hawg 1675-1 Field Replacement: passo 8, imagem 2 %32
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: passo 9, imagem 1 %32
    • Lift the field out of the device, feeding the yellow wire through the handle.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 597
