Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: passo 1, imagem 1 %32
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 2, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 2, imagem 2 %32
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: passo 3, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: passo 3, imagem 2 %32
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 4, imagem 1 %32
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 730
