Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: passo 1, imagem 1 %32
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 2, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 2, imagem 2 %32
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Gear Case: passo 3, imagem 1 %32
    • Set the cover aside so the drill body is visible and can be accessed.
    • The gear case is the silver cylinder part with a black tip in the top of the drill.
  4. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 4, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 4, imagem 2 %32
    • Grip the gear case in one hand while holding the body of the drill with the other.
    • Pull outward to remove.
    • Remove carefully, being mindful of the connecting wires. Damage to these wires can cause permanent damage to the drill.
  5. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 5, imagem 1 %32
    • Check the connection from the motor to the trigger.
    • Check that the connection to the circuit board is intact.
    • If both connections are intact, the gears inside the gear case assembly may be jammed and need to be replaced.
  6. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: passo 6, imagem 1 %32
    • A replacement part can be found on the Milawukee Tool Website under Part NO. 14-30-D012.
Conclusão
Kaylee Rose
Membro desde: 01/16/19
268 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 1,655
