Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Outer Casing: passo 1, imagem 1 %32
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: passo 2, imagem 1 %32
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: passo 3, imagem 1 %32 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: passo 3, imagem 2 %32 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: passo 3, imagem 3 %32
    • Pulling directly outward, remove the driver head from the motor assembly by picking it up out of the casing.
  4. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: passo 4, imagem 1 %32
    • Remove the drive shaft assembly from the motor coils.
    • There will be resistance when removing the drive shaft as there is magnetism working against you.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 747
