Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: passo 1, imagem 1 %32
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 2, imagem 1 %32
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: passo 3, imagem 1 %32
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, imagem 1 %32 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, imagem 2 %32 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, imagem 3 %32
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, imagem 1 %32 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, imagem 2 %32 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 586
