Introdução
The following repair guide shows how to remove and replace the Milwaukee Hex Impact Driver 2750-20 driver head in an easy and effective manner.
O que você precisa
Remove the five T9 15.5 mm screws.
Remove the single T9 19.5mm screw.
Remove the two T9 37mm screws.
Lift the driver head and motor assembly directly out of the outer casing.
Pull the driver head away from the motor assembly, separating the two.
Quase terminado!
Conclusão
