Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: passo 1, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: passo 1, imagem 2 %32
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
    Pergunte ao FixBot
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 2 %32
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
    Pergunte ao FixBot
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: passo 3, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: passo 3, imagem 2 %32
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
    Pergunte ao FixBot
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: passo 4, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: passo 4, imagem 2 %32
    • Gently pull up on the trigger assembly to remove it from the case.
    Pergunte ao FixBot
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: passo 5, imagem 1 %32
    • Remove the trigger assembly from the device.
    Pergunte ao FixBot
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 52
Ao todo: 1,666
