Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: passo 1, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: passo 1, imagem 2 %32
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 2 %32
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: passo 3, imagem 1 %32
    • Gently move the trigger assembly out of the way and remove the switch from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,756
