Ir para o conteúdo principal
Milwaukee Hackzall 2625-20 Gearbox Replacement
O que você precisa
  1. Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: passo 1, imagem 1 %32 Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Gearbox Replacement, Gearbox: passo 2, imagem 1 %32
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws.
    • Pull out the shoe and gearbox to remove the screw on the other side
  3. Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, imagem 1 %32 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, imagem 2 %32 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, imagem 3 %32
    • Using your finger, push the rubber band up then slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, imagem 1 %32 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, imagem 2 %32 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, imagem 3 %32
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. You will use a T15 Torx screwdriver to remove 14.0 mm screws.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,980
