Ir para o conteúdo principal
Milwaukee 5262-21 Power Cord Replacement
O que você precisa
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: passo 1, imagem 1 %32
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: passo 2, imagem 1 %32
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: passo 3, imagem 1 %32 Milwaukee 5262-21 Power Cord Replacement, Power Cord: passo 3, imagem 2 %32
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: passo 4, imagem 1 %32 Milwaukee 5262-21 Power Cord Replacement: passo 4, imagem 2 %32 Milwaukee 5262-21 Power Cord Replacement: passo 4, imagem 3 %32
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: passo 5, imagem 1 %32 Milwaukee 5262-21 Power Cord Replacement: passo 5, imagem 2 %32 Milwaukee 5262-21 Power Cord Replacement: passo 5, imagem 3 %32
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
Conclusão
Adrien Andrade-Cain
Membro desde: 03/08/19
181 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 289
