Ir para o conteúdo principal
Milwaukee 5262-21 Fan Baffle Replacement
O que você precisa
  1. Milwaukee 5262-21 Fan Baffle Replacement, Housing Assembly: passo 1, imagem 1 %32
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Fan Baffle Replacement: passo 2, imagem 1 %32
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: passo 3, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: passo 3, imagem 2 %32
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Fan Baffle Replacement: passo 4, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 4, imagem 2 %32
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Fan Baffle Replacement: passo 5, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 5, imagem 2 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 5, imagem 3 %32
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Fan Baffle Replacement: passo 6, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 6, imagem 2 %32
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Fan Baffle Replacement: passo 7, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 7, imagem 2 %32
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Fan Baffle Replacement: passo 8, imagem 1 %32 Milwaukee 5262-21 Fan Baffle Replacement: passo 8, imagem 2 %32
    • Remove the fan baffle by pulling it out.
Conclusão
Andrew Floyd
Membro desde: 03/08/19
277 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 607
